May 19th, 2024, 1:09pm
[q] verilog-a in hspice (Read 2039 times)
kidhyun
Nov 07th, 2006, 12:35pm
  Pleae let me know how to pass parameters when I instantiate verilog-a module in hspice.
  For example, there is a resistor module in verilog-a.
  Then in hspice I have to do
   .hdl 'resistor.va'
   x1 a b resistor    // when resistor is the module name
   The how can I pass a parameter value (resistor value) here?
   Do I have to make seperate verilog-a module for each resistor with different resistance?
  Thank You
Re: [q] verilog-a in hspice
Reply #1 - Nov 8th, 2006, 10:27am
Did you try
x1 a b resistor r=10k
where "r" is the parameter declared in the module?
I believe the HSpice implementation also allows model cards, eg
x1 a b myres
.model myres resistor r=10k
