rajks1982
Moscow, Idaho
Thanks Ken and Bernd for replying. I did include the extension this time. Here's the message when I run the simulation using spectre. "Simulating `input.scs' on mercury at 11:27:50 AM, Fri Nov 10, 2006. Error found by spectre during circuit read-in. "input.scs" 9: Unable to open input file " `#/projects/**********spectre/ind.scs'. No such file or directory. spectre terminated prematurely due to fatal error." I tried it with a different simulator- spectreS, and I get this message. "Simulating `raw/inductor' on mercury at 11:36:13 AM, Fri Nov 10, 2006. Error found by spectre during circuit read-in. raw/inductor: xl is an instance of an undefined model ind. spectre terminated prematurely due to fatal error." In this case my model files have no extension( like the .scs in spectre mdoels). Any idea where am wrong. Am using a schematic. Do you think if there is any problem in the instance attributes. --Rajeev.
