Jul 17th, 2024, 12:32pm
NQS models and when to use them (Read 4658 times)
vivkr
Nov 14th, 2006, 1:35am
I have read that NQS models are needed to accurately predict some effects, such as charge-injection, or at very high
frequencies. I have some doubts on this subject, particularly with the case of charge-injection.
The basic idea is to use an NQS model if the carrier distribution in the channel does not change fast enough so as to keep
pace with the changes in the terminal voltages (gate voltage).  There are 2 scenarios:
1. An ideal very fast edge square wave turns a MOS switch ON/OFF. The ideal approximation may be achieved by using
say a modern fast signal generator with a MOS transistor which is say 100um-200um long and the process very old (say a 2um CMOS).
2. In a real scenario, the gate of a MOS is probably being driven by another MOS device on-chip. As charge-injection is an issue in switches,
and switches are always made with min. channel length, it is unlikely that the driving edge is so fast that it can change the gate potential of the
controlled MOS switch faster than the rate at which the carrier distribution in the channel can change. This is because the controlling MOS driver itself will experience inertia in responding to its own input. Additionally, there are parasitics on-chip which further slow things down.
So, when do we really need to use NQS models? It would appear that for a typical system, the risetime of any controlling signal generated
on-chip can seldom be fast enough to force the use of such a model, unless one were driving a device which is considerably slower (very large L as in 1.).
Vivek
ACWWong
Oxford, UK
Re: NQS models and when to use them
Reply #1 - Nov 15th, 2006, 7:45am
NQS effects are used in RF circuit design. Modelling NQS effects can improve simulation accuarcy of input impedance, gain and especially noise.... the extend of how much they help/change matters depends on device geometry/layout and operating frequency.... larger devices at higher frequencies means it matters more.
There are quite a few papers out there about NQS CMOS modelling in reference to RFCMOS design of LNA's etc. try a google for NQS RF CMOS
Reply #2 - Nov 16th, 2006, 11:42am
As I understand it, the problem with charge injection is that QS mos models have no idea what to do with the channel charge when the gate is shut off.  For example, in BSIM3/4, the XPART parameter is used to allocate the charge to the drain or source in the ratio 0/100, 40/60, or 50/50.  When you turn a BSIM transistor off, the charge flows out the respective terminal -- regardless of the impedance connected to that terminal!
vivkr
Reply #3 - Nov 17th, 2006, 1:25am
Geoffrey_Coram wrote on Nov 16th, 2006, 11:42am:
Hi Geoffrey,
That sounds like a better reason for using NQS when simulating charge-injection. So what you are saying is that although the phenomenon of charge-injection may not require NQS modelling by itself, the improper modelling of the charge division in the standard QS version of BSIM3 gives incorrect results, and thus we need NQS models, where these effects are presumably modelled correctly.  and characterized correctly.
Vivek
