Apr 28th, 2024, 5:38am
A question about PLL behavior simulation. (Read 3176 times)
Terry
Nov 15th, 2006, 6:38pm
Hi everyone,
     when I use  behavior models for jitter simulation
        such as:
                     Phase-frequency detectors (with jitter)
                     Voltage controlled oscillators (with jitter)
                     getting from http://www.designers-guide.org/VerilogAMS/
    I found that "vco" (with white accumulating jitter) model  conflicted with
                       "pfd_cp2"( with white Gaussian synchronous jitter) model
     when I  add "vco" model even did not connet the "vco"'s "in" pin to "pfd_cp2"'s "out" pin. The
    "pfd_cp2"'s "out" pin was fixed to votage zero , and it has no port current.
     However, when I removed the alone "vco" model , I could see  the voltage of filter that
     connectted to the "out" pin of "pfd_cp2"  hehaved nomally, also I could see the current form the  pin.
     Why the "vco" and "pdf_cp2" model conflicted?
     My simulation tools were  spectre, verilog_A.
     The verilog_A code and netlist is listed behind.
--------------------------do not add vco2----------------------------------------
simulator lang=spectre
global 0
include "/tools/cadence/IC5141/tools.lnx86/dfII/samples/artist/ahdlLib/quantity.spectre"
// Library name: pll
// Cell name: pll_jitter_sim
// View name: schematic
I12 (net09 net08) divider2
V0 (net08 0) vsource type=pulse val0=2.5 val1=0 period=200.0n rise=1n \
       fall=1n width=100.0n
V1 (net022 0) vsource type=pulse val0=2.5 val1=0 period=30.52u rise=1n \
       fall=1n width=15u
C6 (net8 0) capacitor c=84p
C0 (net010 0) capacitor c=547p
R0 (net8 net010) resistor r=200K
I11 (net8 net022 net09) pfd_cp2
tran tran stop=1m write="spectre.ic" writefinal="spectre.fc" \
   annotate=status maxiters=5
---------------------------------add vco2--------------------------------
global 0
I18 (net012 net011) vco2
       fall=1n width=15u
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="../psf/sens.output" checklimitdest=psf
// vco
// Voltage controlled oscillator with white accumulating jitter
module vco2 (out, in);
input in; voltage in;                        // input terminal
output out; voltage out;                  // output terminal
parameter real vmin=-0.5;                        // input voltage that corresponds to minimum output frequency
parameter real vmax=vmin+2.5 from (vmin:inf);      // input voltage that corresponds to maximum output frequency
parameter real fmin=-20M from (-inf:inf);            // minimum output frequency
parameter real fmax=100M from (fmin:inf);      // maximum output frequency
//parameter real fmax=2*fmin from (fmin:inf);      // maximum output frequency
parameter real vl=0;                        // high output voltage
parameter real vh=2.5;                        // low output voltage
parameter real tt=0.01/fmax from (0:inf);      // output transition time
parameter real ttol=1u/fmax from (0:1/fmax);      // time tolerance
parameter real jitter=1n from [0:0.25/fmax);      // period jitter (produces white accumulating jitter)
real freq, phase, dT;
integer n, seed;
analog begin
   @(initial_step) seed = -561;
   // compute the freq from the input voltage
   freq = (V(in) - vmin)*(fmax - fmin) / (vmax - vmin) + fmin;
   // bound the frequency (this is optional)
   if (freq > fmax) freq = fmax;
   if (freq < fmin) freq = fmin;
   // add the phase noise
   freq = freq/(1 + dT*freq);
   // bound the time step to assure no cycles are skipped
   $bound_step(0.05/freq);
   // phase is the integral of the freq modulo 2p
   phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
   // update jitter twice per period
   // `M_SQRT2=sqrt(K), K=2 jitter updates/period
   @(cross(phase + `M_PI/2, +1, ttol) or cross(phase - `M_PI/2, +1, ttol)) begin
     dT = `M_SQRT2*jitter*$rdist_normal(seed,0, 1);
     n = (phase >= -`M_PI/2) && (phase < `M_PI/2);
   // generate the output
   V(out) <+ transition(n ? vh : vl, 0, tt);
Terry
Re: A question about PLL behavior simulation.
Reply #1 - Nov 15th, 2006, 6:41pm
// This model exhibits white synchronous jitter
module divider2 (out, in);
input in; voltage in;            // input (edge triggered)
parameter real vh=+2.5;            // output voltage in high state
parameter real vl=0;            // output voltage in low state
parameter real vth=(vh+vl)/2;      // threshold voltage at input
parameter integer ratio=800 from [2:inf);      // divide ratio
parameter integer dir=1 from [-1:1] exclude 0;
                       // dir=1 for positive edge trigger
                       // dir=-1 for negative edge trigger
parameter real tt=1n from (0:inf);      // transition time of output signal
parameter real td=100n from (0:inf);      // average delay from input to output
parameter real jitter=10n from [0:td/5);      // edge-to-edge jitter
parameter real ttol=1p from (0:td/5);      // time tolerance, recommend ttol << jitter
integer count, n, seed;
real dt;
analog begin
   @(initial_step) seed = -311;
   @(cross(V(in) - vth, dir, ttol)) begin
     count = count + 1; // count input transitions
     if (count >= ratio)
         count = 0;
     n = (2*count >= ratio);
     dt = jitter*$rdist_normal(seed,0,1); // add jitter
   V(out) <+ transition(n ? vh : vl, td+dt, tt);
// This model exhibits white gaussian synchronous jitter
module pfd_cp2 (out1, ref, vco);
output out1; electrical out1;      // current output
input ref; voltage ref;            // positive input (edge triggered)
input vco; voltage vco;            // inverting input (edge triggered)
parameter real iout=2u;      // maximum output current
parameter real vh=2.5;            // output voltage in high state
parameter real td=5n from (0:inf);      // average delay from input to output
parameter real jitter=0.8n from [0:td/5);      // white edge-to-edge jitter
integer state, seed;
real dt;
analog begin
   @(initial_step) seed = 716;
   @(cross(V(ref)-vth, dir, ttol)) begin
     if (state > -1) state = state - 1;
   @(cross(V(vco)-vth, dir, ttol)) begin
     if (state < 1) state = state + 1;
   I(out1) <+ transition(iout*state, td + dt, tt);
