Aug 18th, 2024, 3:12am
problem about large signal and small signal (Read 2733 times)
dragonnj
Nov 15th, 2006, 7:20pm
it is said to design PA should use large signal S-parameters, but in another book(Mihai Albulet's RF Power Amplifiers),it is said that "There is no evidence of successful use of large-signal s-parameters in
designing RF PAs above a few watts of output power."
I just wonder what is large signal S-parameters? what is the difference between large signal and small signal? and how to use large signal in my PA designing?
thanks
Dragon
ACWWong
Oxford, UK
Re: problem about large signal and small signal
Reply #1 - Nov 16th, 2006, 2:23am
see the following topic which should answer your queries...
http://www.designers-guide.org/Forum/YaBB.pl?num=1031864062
dragonnj
Reply #2 - Nov 16th, 2006, 5:32pm
thank you very much!
------Dragon
