Aug 15th, 2024, 6:25am
How to replace "wait" in synthesis ?!? (Read 1385 times)
AdamPod
Nov 26th, 2006, 11:54am
Hi, I need to replace "wait" statement in order to perform synthesis of my behavioral model... Is there any known way to do this ?!? I found on the www.eecs.berkeley.edu/~chinnery/synthesizableVerilog.html website some solution, by it does not fulfil all my requirements. Below is a peace of my code I need to synthesize:
always@(state)
begin
    case (state)
read:
    begin
          XEN_EEPROM_Read <= 1'b1;
          eeprom_reading <= 1;
          ER <= read_test_count;
          wait (eeprom_reading == 0);
          if (ED_int == EV_test)
                failure <= 0;
          else
                failure <= 1;
          parity <= ~parity;
          read_test_count <= read_test_count + 1;
          state <= idle;
eeprom_reading signal is set to zero when appropriate counter reach given value - the whole process is put in separate "always" block. In the rest of the cases there is no more of "wait" statements. I will be glad if anyone knew how rewrite this code properly and could gice my some hint.
