Hi, I need to replace "wait" statement in order to perform synthesis of my behavioral model... Is there any known way to do this ?!? I found on the
www.eecs.berkeley.edu/~chinnery/synthesizableVerilog.html website some solution, by it does not fulfil all my requirements. Below is a peace of my code I need to synthesize:
always@(state)
begin
case (state)
read:
begin
XEN_EEPROM_Read <= 1'b1;
eeprom_reading <= 1;
ER <= read_test_count;
wait (eeprom_reading == 0);
if (ED_int == EV_test)
failure <= 0;
else
failure <= 1;
parity <= ~parity;
read_test_count <= read_test_count + 1;
state <= idle;
eeprom_reading signal is set to zero when appropriate counter reach given value - the whole process is put in separate "always" block. In the rest of the cases there is no more of "wait" statements. I will be glad if anyone knew how rewrite this code properly and could gice my some hint.
