Jul 17th, 2024, 12:26pm
Vt vs. Length of MOS (Read 7952 times)
RDCam
Cambridge, UK
Nov 27th, 2006, 2:05am
I noticed the trend of Vt (threshold voltage) Vs. Length (um) for the low-vt  nchannel MOS transistors in recent sub-micron technologies has changed. Previously the Vt for shorter channel lengths would be lower, but now it seems significantly higher cmopared to longer channel(>2u). The gradient of the Vt Vs L curve for L <~1.5u is very high.  Are there any process experts who can explain this ? Will greatly appreciate any clarification on something that has been bugging me for a few months already!
ACWWong
Oxford, UK
Re: Vt vs. Length of MOS
Reply #1 - Nov 27th, 2006, 7:27am
Perhaps you are seeing the "Reverse-short-channel effect" which is an increasing vth with decreasing L to a peak, before vth again decrease at very short channels.... perhaps your vth vs L hump is just under 1.5um.
Try looking at something Tsividis "the MOS transistor" or googling it.
RDCam
Cambridge, UK
Reply #2 - Nov 28th, 2006, 3:43am
The keyword RSCE is exactly what I was looking for. Once I could label the phenomenon I am able to find literature on it ! Thanks a lot.
Croaker
Reply #3 - Nov 28th, 2006, 8:36am
Basically it has something to do with the way the p-dopant diffuses, creating a higher Vth, even though Vth should be getting lower with channel-length.
Please post a link to any good explanatory page about this.
