Jul 20th, 2024, 6:32pm
AMS cannot netlist cells (Read 2468 times)
Pavel
Lausanne/Switzerland
Dec 05th, 2006, 9:28am
Hello
Doing Design Preparation procedure (Hierarchy Editor->AMS->Design Prep...) I receive in Messages window of Hierarchy Editor about 10 messages like this:
Netlisting LIB_ANLG cell12 schematic.
AMS Netlister is unable to netlist LIB_ANLG cell12 schematic.
Search for 'Error' in the AMS->Logfile Viewer->Netlister Log File  for details.
Netlisting failed for cellview LIB_ANLG.cell12:schematic
Netlist isn't created, so I cannot run simuation.
Following suggestion I checked Netlister Log File. There is absolutely NOTHING that explains the problem.
The cells that are not netlisted (7 cells) represent minor quantity from whole number of cells, that are netlisted. I tried to find the diffrences between "BAD"  and "GOOD" cells. No major differencies - just other cells.
How can I bypass the problem if tool diagnostic is zero?
Thanks in advance.
Regards.
Pavel.
zhong
California , United States
Re: AMS cannot netlist cells
Reply #1 - Dec 10th, 2006, 3:31pm
It seems to me  schematic cells did not get "check and saved " .
Try this
In top level configured schematic window, Check -> Hierarchy ..  turn on all schematic and turn on check .
After hierarchy check done . Do design Prep again .
