Aug 18th, 2024, 3:18am
Does the PA-Driver need on-chip bypass caps (Read 2566 times)
michael_li
Dec 07th, 2006, 10:40pm
The 2000M PA-Drvier is a common-emitter SiGe BJT amplifier with on-chip about 7nH RFC inductor, gnd pad bonding to exposed pad, and the output power is 8dBm while meeting the ACLP requriments , so dose the PA-Driver need on-chip supply bypass caps to minimize the supply bondwire effect, or for other reasons, in your experence ?
Please give me some suggestions!!
WillN
San Diego
Re: Does the PA-Driver need on-chip bypass caps
Reply #1 - Dec 8th, 2006, 1:29pm
It depends on whether your bondwire is part of you matching circuit for presenting optimum load to the collector. The ultimate target is to present a load (with all parasitics) that allow you to extract the power at reasonable efficiency while meeting your ACLP requirement.
Will
michael_li
Reply #2 - Dec 8th, 2006, 9:58pm
Thank you William.
Roll Eyes
