Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 18
th
, 2024, 1:19am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› basic doubt
Previous topic
Next topic
basic doubt (Read 2863 times)
sivacha
India
basic doubt
Dec 14
th
, 2006, 6:26am
In RF design, we consider the load as port( dc source) and the port resistance as the load.
I dont understand why can't we consider direct resistance instead of using port??
Thank You,
Siva.
IP Logged
Re: basic doubt
Reply #1 -
Dec 14
th
, 2006, 8:02am
You can, but if the source voltage is zero, they are equivalent. The port is only needed if you want to measure the s-parameters. It is used when computing s12 and s22.
IP Logged
aaron_do
Re: basic doubt
Reply #2 -
Dec 14
th
, 2006, 5:27pm
I'm not 100% sure but I think the output port resistance is de-embedded from the noise figure...anyone know for sure? i.e. if you use a 50 ohm resistor in simulation you will get different results than if you use a port...
Aaron
IP Logged
Re: basic doubt
Reply #3 -
Dec 14
th
, 2006, 11:17pm
If you tell the noise analysis that the resistor is the load as you would with the port, then the results are identical.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
