didac
![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif)
![](https://designers-guide.org/forum/avatars/blank.gif)
There's a million ways to see the things in life
manresa,spain
Without more info I guess that the Mixer output is in current mode. If you want to see a current in Spectre you must first select like an Outputs-->to be saved. After saving it in the form you can run the simulation and you can view the output without further problems.
