Apr 29th, 2024, 6:49pm
Gm (Read 3495 times)
sivacharan
Gm
Dec 17th, 2006, 10:09pm
To measure the transconductance of the mixer i used QPSS analysis.
But after running the simulation, i clicked on the output node of the port.
But the tool is saying "res/PLUS is not a kept output".
What does it mean??
Thank you.
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Gm
Reply #1 - Dec 17th, 2006, 11:07pm
Without more info I guess that the Mixer output is in current mode. If you want to see a current in Spectre you must first select like an Outputs-->to be saved. After saving it in the form you can run the simulation and you can view the output without further problems.
sivacharan
Re: Gm
Reply #2 - Dec 18th, 2006, 12:10am
didac,
yes, my mixer output is current. i didn't save the output node to plot current.
i got the result after saving the output node on the outputs list.
Thank you didac....
