Apr 26th, 2024, 4:31pm
node capacitance (Read 6470 times)
sivacharan
node capacitance
Dec 18th, 2006, 8:17pm
If i want to see the total capacitance occuring at a particular node, which simulation will be useful in spectreRF??
Thank you.
Re: node capacitance
Reply #1 - Dec 18th, 2006, 10:22pm
If you are running standalone you would run an info analysis ...
Quote:
printCapacitanceTable info what=captab
If you are running in Artist, you might be able to specify that this through the Artist UI, but I am not familiar with how you would do that. Alternatively, you can put that statement in a file and tell Artist to include it in the netlist.
ACWWong
Oxford, UK
Reply #2 - Dec 19th, 2006, 2:53am
In artistADE, you can tick the captab button in choose analyses->dc->options or choose analyses->tran->options.
In DC you get the node capacitances calcualted from the dc op point.
in tran you can get the node capacitances at different time points using "infotimes"
sivacharan
Reply #3 - Dec 19th, 2006, 11:14pm
when i see the dc operating point of an nmos or pmos, the spectre tool is showing the -ve capacitance for cgs and cds ...etc.
what does it mean??
thank you.
ACWWong
Oxford, UK
Reply #4 - Dec 20th, 2006, 3:23am
sivacharan wrote on Dec 19th, 2006, 11:14pm:
what does it mean??
See the following relevant post.
http://www.designers-guide.org/Forum/YaBB.pl?num=1160834621
Please bear in mind that the dc-opertaing points for any transistor are model parameters, whereas as captab gives total capacitance on nodes/nets in a circuit.
