Sep 17th, 2024, 7:14pm
two stage ring vco question? (Read 4253 times)
email_gz
gaoz.mail@gmail.com
Dec 19th, 2006, 8:57pm
Hi everybody
   I got puzzled by two stage ring vco oscillation . As we kown in frequency domain , Barkhausen criteria tell us , a two stage ring vco can oscillation at a special w, only if each delay cell  transfer function satisfy:
∠Av(jw)≥90 Degree ,and |Av(jw)| ≥1.
   I simulated a pmos cross-coupling positive feedback delay cell .
  Hspice ac analysis resault : its ac phase shift is only about 54 degree when its gain drops to unit.
  So theoretically, a two stage ring vco builded by this delay cell should not oscillate at time domain .
  But Hspice tran analysis gives  a contrary result . But Why???
  Any suggestion is welcome!!!
View Profile email_gz email_gz   IP Logged
email_gz
gaoz.mail@gmail.com
Re: two stage ring vco question?
Reply #1 - Dec 19th, 2006, 8:58pm
tran
email_gz
gaoz.mail@gmail.com
Reply #2 - Dec 19th, 2006, 9:07pm
schematic vco 2 stage
jeffyan
Reply #3 - Dec 20th, 2006, 2:36am
hi,
i think, you should make it clear to us that what is your transfer function related in your plot ?
if it is Vop/Vip, then i think, the phase is right, because it >180 degree, which is needed for stable oscillation.
if not, i think, you should check your ckt simulation, if the ckt work in its right operation, because it might be latched to two rail supplies.
good luck
jeff
email_gz
gaoz.mail@gmail.com
Reply #4 - Dec 20th, 2006, 6:16pm
jeff ,thanks for your reply!
My ac analysis tool is hspice and input output configuration as following:
******input
vctrn ctrn gnd! 1.8v
vdm dm gnd! dc 0v ac 1v
vcm cm gnd! 0.9v
e1 vip cm dm 0 1
e2 vin cm dm 0 -1
******output
.op
.ac dec 20 0.1 10000Meg
.pz v(vop,von) vdm
.print vdb(vop)
.print vp(vop)
.print vdb(von)
.print vp(von)
Hope these can give you some helpul information
                                     email_gz
