Jul 18th, 2024, 4:17am
Low-Noise CMOS Opamp ICs? (Read 3596 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Dec 19th, 2006, 9:55pm
Hi all, can you recommend me some good low-noise CMOS opamp ICs? I am studying low-noise CMOS opamps now, so I need to refer to some classic structures. Cool
Best regards,
Terry
carlgrace
Berkeley, CA
Re: Low-Noise CMOS Opamp ICs?
Reply #1 - Jan 4th, 2007, 6:48am
Terry,
Sadly, there isn't much you can do to lower the noise of a CMOS op amp aside from the obvious (passive loads, tons of current to get high gm in the input stage, etc.).  Generally, you just optimize for noise, there aren't any fancy low noise topologies.  Sorry.  Adding devices adds noise, so the lowest noise structures are the simplest.
Carl
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #2 - Jan 7th, 2007, 7:45pm
carlgrace wrote on Jan 4th, 2007, 6:48am:
Terry,
Carl
Hi Carl,
Thanks for your reply, but can you recommend me some good commercial ICs regarding low-noise and low-power Opamps, your suggestions will be highly appreciated.
Terry
avlsi
singapore
Reply #3 - Jan 9th, 2007, 12:10am
U can search Analog or TI for chopper stabilization operational amplifiers. They are low noise.
But the real fun is in designing one such opamp and then measuring the results. I think former is quite possible. U can start to design a simple low noise opamp using Two -stage miller opamp topology for flicker noise.
Winners never Quit,Quitters never Win
