Apr 30th, 2024, 1:40pm
Passing 'errpreset' paramter in MDL (Read 6493 times)
topquark
Thames Valley, UK
Jan 03rd, 2007, 1:26am
Hi folks!
I wrote a simple MDL script for a tran analysis, but was unable to pass the accuracy parameter 'errpreset'.
The log shows that it always takes the default (=moderate)
I want it to be changed to 'conservative' during run.
The analysis line-
run tran(stop=15us,  maxstep=1ns)
doesn't seem to accept errpreset as an argument and errors out.
The help documentation doesn't show how to do this, it just shows how to pass other numeric parameters like
transtop, step etc..
Anybody got an idea?
Gau
ACWWong
Oxford, UK
Re: Passing 'errpreset' paramter in MDL
Reply #1 - Jan 3rd, 2007, 5:43am
The way round this would be to use the run command to call a named rather than primitive (tran, ac, dc etc.) analyses. That way you can add the errpresent setting in the netlist.
John O Donovan
San Jose, CA
Reply #2 - Jan 3rd, 2007, 9:16am
The following should work
    run tran(stop=15us, errpreset='conservative, maxstep=1ns)
I would remove the maxstep paramter though. It generally has no impact on simulation results in Spectre other than slow down simulation, if given a very small value. If you are using threshold type functions (cross, deltax, risetime, ... ), Spectre will place timepoints automatically at the crossing points. If you require fixed timesteps for FFT's then use a z domain controlled source, or strobing parameters.
 John
topquark
Thames Valley, UK
Reply #3 - Jan 4th, 2007, 12:27am
Hi John!
Thanks for supplying that essential apostrophe " ' "
I've got my code working right away..
I was wondering if maxstep affects the 'errpreset' or the latter overrides the former?  ::)
Ref: www.designers-guide.org/Forum/YaBB.pl?num=1162459212
Gau
Reply #4 - Jan 4th, 2007, 8:46am
The 'preset' in errpreset is meant to imply that it takes effect before processing the remaining parameters. In otherwords, errpreset effectively adjusts the defaults of the other parameters according to the mood of the user. As such, any values that you specify for parameters affected by errpreset will take precedence.
