Jul 8th, 2024, 3:17pm
SpectreRF PLL phase noise simulation? (Read 3294 times)
Visjnoe
Jan 04th, 2007, 3:18am
Dear all,
is it possible to use SpectreRF to simulate the closed-loop PLL phase noise performance at transistor level?
Just assuming that simulation time is no issue, has anyone experience on this?
Is it difficult to get convergence? I know for example that EldoRF has difficulty converging when a LC-VCO and a subsequent CML + asynchronous FF-style divider are combined, so I never even tried full PLL simulation with it...
Kind Regards
Peter
Re: SpectreRF PLL phase noise simulation?
Reply #1 - Jan 4th, 2007, 8:54am
As long as the PLL has a periodic solution (no deadzone in the PFD) it should work fine. I have seen that harmonic balance based simulators tend to have an inordinate amount of difficulty with frequency dividers, but SpectreRF does not because it uses shooting methods.
Visjnoe
Reply #2 - Jan 4th, 2007, 10:48am
Dear Ken,
thanks for your comment.
If I understood your comment right, you expect SpectreRF to converge as long as there's a periodic solution, which would indeed be an improvement over EldoRF.
Do you think that a reference input signal that is dithered with jitter poses problems for SpectreRF? The goal would be to verify the input CLK jitter attenuation using such a set-up.
Kind Regards
Peter
Reply #3 - Jan 4th, 2007, 11:53am
Jitter would definitely be a problem if you were trying to use the PSS analysis, because the solution would not be periodic. Envelope following might work. Or you could explore the jitter attenuation by using PAC while phase modulating the input source (you could use the PM modulator in http://www.designers-guide.org/VerilogAMS/functional-blocks/modulators/modulator... while driving the modulation input with a small-signal source (a DC voltage source with pacmag=1)).
