Thank you Ken for your explanation! :)
At first I thought the PAC simulation results reflected transfer functin (conversion gain) but got confused when they varied with input levels; my logic was if they measured transfer function they should be independent of the input magnitude.
![Embarrassed Embarrassed](https://designers-guide.org/forum/Templates/Forum/default/embarassed.gif)
BTW, why don't the results remain constant?
I should have stated my motivation for using PSS-PAC in my previous posting. I am trying to use the tool to analyze the RF immunity characteristics of targeted circuits by measuring the resulting distortions when large RF signals with different types of modulation are applied. I thought conducting IIP3/OIP3 simulations would not distinguish between the AM and PM types of the source (RF) signal, and thus, somehow, not accurate.
Should I not worry about the types of moduation when the blocker signal is the modulated signal(RF) itself? That is, in your opinion, would IP3 simulations, which in this case would be treating the modulated contents as blocker signals, be the best way to analyze the RF immunity characteristics (measuring distortions-levels, waveforms) of target circuit? Other than transisent simulation(which takes too much time), of course. I would really appreciate your opinion or advice.
Best regards,
NKS
