Aug 15th, 2024, 9:36pm
How to time-average capacitance by RF simulator (Read 3939 times)
neoflash
Mixed-Signal
Designer
Jan 06th, 2007, 7:36pm
When designing LC-tank based oscillator, we need to analyze the tuning curve of frequency.
Instead of directly running LC-tank with active circuits, I hope that I could have a look at the tuning curve of the varactor.
Instead of the DC tuning curve which is easily available, I would like to see the effective capacitance of the varactor at certain voltage waveform.
Can eldoRF do this? Can SpectreRF do this? Which document refers to the setup and theory?
Neoflash
Re: How to time-average capacitance by RF simulato
Reply #1 - Jan 6th, 2007, 7:56pm
Spectre can do this (you don't need SpectreRF). Just apply an AC voltage source directly to the varactor (try to eliminate any series resistance) and perform an AC analysis at a fixed frequency while sweeping the control voltage on the varactor. The imaginary part of the current equals ωC. Just divide through by ω to get C.
neoflash
Mixed-Signal
Designer
Reply #2 - Jan 6th, 2007, 10:02pm
Ken:
The average capacitance I want to observe is just like what is mentioned in Emad's book.
The capacitance obtained in your method is the small signal capacitance at certain DC biasing point. However, I thought there is also some way to get average capacitance. When we run that simulation, we need to specify input voltage amplitude and DC voltage. Thus, simulator will plot us a curve of average capacitance.
I see this mentioned in one recently pulished jssc paper, but i can not remember the title. I will check when I was back in office.
Neoflash
Reply #3 - Jan 6th, 2007, 10:46pm
Whoops. I overlooked the words "time-average" in the title. I think you can follow the same procedure using PSS and PAC. I believe the 0th sideband would correspond to the average capacitance.
neoflash
Mixed-Signal
Designer
Reply #4 - Jan 7th, 2007, 5:03am
Ken:
Thanks for the information. But I can not locate any reference doc or application notes on this.
I guess I do not like got some results without knowing its physical meaning. Maybe I can try to acess Cadence AE, however, I doubt supporting groups in my region knows what I want.
It could be nice if you have some demo there.
Reply #5 - Jan 7th, 2007, 11:15am
I don't have a copy of Emad's book, so I don't know exactly what you are trying to do. But I can tell you what the PSS/PAC set up is doing.
You apply the range of control voltages that you are interested in in the form of a large signal periodic stimulus to the varactor. Then in addition you apply a small sinusoidal test tone at a particular frequency. That test tone will generate responses at that frequency and related sidebands. Examining the 0th sideband is equivalent to attaching a spectrum analyzer to the circuit and examining the response at the same frequency as the test tone. The magnitude of the response will be related to the average value exhibited by the capacitance weighted by the shape of the large stimulus waveform. You should be able to work through the mathematics to prove that to yourself.
rf-design
Reiner Franke
Reply #6 - Feb 4th, 2007, 2:35pm
The possible background of your question is to estimate the shift of the oscillation frequency of a tank dominated circuit. That requires that you calculate the effective capacitance for the first harmonic current. If the tank capacitane is primary current driven by the tank inductance you have to use a current source. Use a sine current source and extract the first harmonic voltage amplitude and phase. If the capacitance is not ideal you will observe phase differing from -90°. If you change the current amplitude you will observe a nonlinear change of the cophase component voltage. That indicate that the oscillation frequency will change with amplitude. Also known as AM2FM conversion effect.
I also observe that there is also bias shift effects in the circuit which are difficult to differentiate from the above effect. These DC bias shift too modify the oscillation frequency via the cap nonlinearity. Therefore the circuit is studied by selectively switching in/out the effect in the model and simulating the hole circuit instead of only the components.
