Being able to simulate in spectre doesn't really mean that much... AMS is simulated rather differently.
Are you specifying properties for specific instances or cells? For example, the view to use set to sourcefile?
It's hard to know without seeing what you're doing. Can you look in your library in the config view you're using, and see if there's a file in there called prop.cfg - if so, can you post it here?
Also, what version are you using (of the simulator, and the envrionment) (ncsim -version and icfb -W will reveal this info)
