Jul 20th, 2024, 8:18am
ams designer starts and then hangs (Read 2359 times)
southofthebay
Jan 10th, 2007, 6:12pm
I am trying to run an AMS Designer simulation involving pure verilog rtl and verilogAMS converted from a PLL schematic.
I have a weird problem: when I try to reset the charge pump inside of the PLL (either with a digital control pin or with a vpwl inside the schematic), the simulator hangs. I hold reset on at t=0 and then release it sometime later t>0. The simulation starts fine and runs until reset is released. It then runs for several hundred ns more. The simulation step size then decreases where it becomes 1 fs and then hangs.
Do any of you have some suggestions as to what is causing the problems?
southofthebay
jbdavid
Re: ams designer starts and then hangs
Reply #1 - Jan 22nd, 2007, 8:11pm
first thing I'd consider is:
Look to see if you have used a non-discrete variable as the argument to a "transition" statement..
Since it sounds like you are using schematic (analog) + digital and no Verilog-AMS models other than the
connect modules, I'd double check those too... Are you using the right set? are they the latest version?
Are you using a recent IUS release? (ie 5.7 or 5.8 or higher?)
ALSO check the convergence settings. (after all THAT's whats getting bogged down.
jbd
jbdavid
