Jul 16th, 2024, 10:27am
noise model of ota (Read 1473 times)
parthsv
noise model of ota
Jan 14th, 2007, 8:47am
Hi All,
I am building a pipeline ADC and in order to verify certain aspects of the ADC i have built a verilogA model of the ADC. I need to incorporate thermal noise of the opamp/comparator of each stage of pipeline and I am new to noise modelling in verilogA. Can anyone here please give me directions on how to proceed in verilogA?
 Thanks in Advance.
Re: noise model of ota
Reply #1 - Jan 15th, 2007, 5:19am
Are you planning to run a noise/pnoise simulation (in which case you can use white_noise()), or do you need to implement something that will work in a transient analysis?
parthsv
Reply #2 - Jan 15th, 2007, 9:46pm
Thanks for your respone. I need to include thermal noise in transient analysis.
Visjnoe
Reply #3 - Jan 16th, 2007, 12:45am
Dear parthsv,
To include thermal (white noise) into your transient simulation, you have several options:
1. If you have access to ELDO, you can include noise sources (ELDO primitives) into your schematics.
   They will inject noise during transient analysis.
2. Otherwise, generate a random number stream (using MATLAB or an AHDL) and include this into your
   simulation. Make sure that you control the noise power well in this case by using a fixed time step!
   If you want  'shaped'  (e.g. 1/f) noise, pass the random number stream through a digital filter.
Kind Regards
Peter
parthsv
Reply #4 - Jan 16th, 2007, 5:30am
Hi Visjnoe,
 I already have actual noise numbers(rms voltage/power) per stage from the circuit simulation. Is there a way to include these numbers in the simulation setup?
Reply #5 - Jan 16th, 2007, 6:24am
parthsv wrote on Jan 16th, 2007, 5:30am:
Hi Visjnoe,
The rms voltage should be used to set the scaling for the random number generator, but since you're doing transient, you still need to generate the random numbers!
Reply #6 - Jan 17th, 2007, 3:09am
Note that if you include noise using the usual verilog-a noise functions, then that noise will be included in a spectre transient noise simulation. Of course, you'll get the noise from all the devices in the circuit too - so if you only want to include the noise from this model, then you'd have to use the random number generator approach that others have suggested in this thread.
