May 10th, 2024, 1:03pm
Any reason why people used Nsub for analog .. (Read 3691 times)
phawk
Jan 15th, 2007, 11:01am
Is there any reason why people used nsub for analog switch chip design?
Thanks!
Re: Any reason why people used Nsub for analog ..
Reply #1 - Jan 22nd, 2007, 5:38am
PHAWK,
  There are several reasons why for reasons using n-substrate. First
some background,
1) MOSFET transistors are majority carrier devices.
2) N-channel devices have lower rdson per unit area so n-channel
   devices are preferred.
3) In the past, short-channel transistors were created by doping the
    MOSFET body, p-well, and source through a single oxide window.
   The boron out diffuses the Arsenic and forms the body of the n-channel
   transistor.
   To build this type of structure means that the drain needs to be
   built into a lightly-doped region usually an epitaxial layer. However,
   lightly-doped regions mean high resistance so the device needs to
   built on a highly doped substrate region for example an buried
   collector region or an n-wafer.
4) The benefit of creating the drain in a lightly-doped epitaxial region
   is that the doping concentration of the lightly-doped region determines
   the breakdown voltage of the junction. So the BVdss, the drain
   source breakdown voltage is maximized.
   So n-channel DMOS transistor structure is preferred for building high
breakdown devices.
5) In many applications, for example, automotive, high-sided switches
   are used for safety reasons(I've heard). A low side switch is connected
   from the load to ground so the load floats when the switch is open.
   For a high-side switch, the switch is between the source and load so
   the load is grounded when the switch is open.
   If a high-side switch were built in a p-substrate, the substrate is grounded.
   As a result, the breakdown is limited by the substrate to drain breakdown
   voltage. In addition, the current handling capability is limited compared
   to an n-substrate device. The drain's thickness and resistivity are limited
   by the need to build the transistor on a p-substrate.
   So to build high power density, high-voltage, high-sided switches n-substrates
are preferred to p-substrates.
phawk
Reply #2 - Jan 30th, 2007, 2:00pm
Hi sheldon,
Thanks a lot!
-phawk
