Sep 5th, 2024, 10:28pm
Buffer power simulation (Read 1647 times)
Visjnoe
Jan 16th, 2007, 2:14am
Dear all,
a bit of a trivial question maybe, but I has me puzzled and I can't find a metric to decide which one is better:
when simulating (transient) power consumption should we extract the average current or RMS?
Kind Regards
Peter
SRF Tech
Arizona
Re: Buffer power simulation
Reply #1 - Jan 16th, 2007, 6:45am
I have always struggled with this myself.  Over the last few years I have settled on measuring total power (not averaged) as a function of activity factor.  I usually also give a max power consumption which is the extracted full power with an activity factor of 100% as well as stand-by leakage current.  I am still uncertain as to what the benefit is in detailing the average or RMS power of an I/O buffer (though it is useful internally when considering Electro-migration reliability issues along your power rails and interconnect, in which case I do use average, but this is generally not a value that I publish in my design reviews or datasheets).
Possibly some else has a different perspective?
Note that these comments mostly apply to standard push-pull CMOS buffers.  Serial interfaces (if using a current steering architecture) are a little easier to detail as they tend to have nice DC bias currents with little current (i.e.  read as 'power') variation as a function of signaling transitions.
CORRECTION:  I thought about it after I posted; current calculations for Electro-Migration issues depends on the process technology you are using, some use an extrapolated calculation based on Idc and capacitive loads, others use Irms or Iaveraged currents depending on the modeling.  Ergo my comment on the fact that I use the average for internal electro-migration is not entirely accurate.
« Last Edit: Jan 16th, 2007, 8:29am by SRF Tech »
www.srftechnologies.com
Visjnoe
Reply #2 - Jan 17th, 2007, 6:44am
I tend to think that average current consumption is the right metric.
If a constant voltage source V delivers a current A for half of the time and receives a current A for half of the time (current flow changes direction), the net power consumption is zero (voltage source delivers and receives equal amounts of power).
RMS would however result in a power consumption of V*A.
Agree?
Kind Regards
Peter
« Last Edit: Jan 17th, 2007, 8:07am by Visjnoe »
SRF Tech
Arizona
Reply #3 - Jan 17th, 2007, 9:56am
Peter,
I am not certain we are discussing the same concept of transient power consumption.
Your comment about current leaving a voltage source and then returning (i.e changes direction) makes me think that you are looking at one of two options:  the power delivered into a capacitive load, where first it is charged up by the buffer and then it is discharged by the buffer; or more correctly maybe you are thinking of a buffer driving a load resistor tied to some VCM or VDD/2 where when driving high, our buffer sources current and when driving low we sink current... either way I am not sure exactly what you mean then by transient power consumption because this is the current moving in and out of the Buffer output, not necessarily the power consumed by the buffer.
My perspective on buffer power consumption was that I thought you meant the power consumed by a CMOS driver driving a capacitive/CMOS load... (I ignored external pull-up/down loads as that would be a system level power consumption question.  In this case, I am only concerned with the current sourced by my VDD supply to the buffer.  This current is only sourced when I drive a high value (as driving a 0 simply sinks current from the load capacitor into my VSS).  Ergo, my current is dependent how how often I drive that high value and that is why I tied it to activity factor.
So, I guess my question for you is, are we discussing the same buffer/topology/situation etc.?
-SRF Tech
mg777
Reply #4 - Jan 17th, 2007, 12:15pm
If the power is being dissipated in a resistor then you do RMS. OTOH if the power is drawn from a voltage source you find the average.
Reason: in either case you want the following:
P_{ave} = \frac{1}{T} \int{0}{T} v(t) \times i(t) dt
where T is a suitably chosen time interval. It's easy to see that in the resistor case you'll get i^2 inside the integral (RMS), while in the voltage source case the constant V_dd will come out of the integral and you'll get average.
To answer the other question posed, for Class A operation the average power draw is indeed equal to the quiescent power. Not so for saturating amplifiers with switching inputs, as pointed out by earlier posters.
M.G.Rajan
www.eecalc.com
bharat
Reply #5 - Feb 6th, 2007, 11:16pm
I have a question from both SRF and Rajan.
SRF wrote:
In this case, I am only concerned with the current sourced by my VDD supply to the buffer.  This current is only sourced when I drive a high value (as driving a 0 simply sinks current from the load capacitor into my VSS)... my current is dependent how how often I drive that high value and that is why I tied it to activity factor.
I AM NOT CLEAR HERE. FROM THE PREVIOUS POSTS IT IS SAID THAT THE POWER IS GOING BACK TO VSS. BY MAKING THE ACTIVITY FACTOR AS 0.5 CAN WE ONLY CONSIDER THE CURRENT SOURCED TO BUFFER. WILL THE RESULT BE SAME IF I CONSIDER THE CURRENT SINKED TO VSS ALSO WITH ACTIVITY FACTOR 1.
Rajan:
I am gettng that for any push-pull amplifier or for a inverter the Power is calculated by avg current, which will be close to zero (except leakage current).
Please comment.
mg777
Reply #6 - Feb 8th, 2007, 6:10am
"I am gettng that for any push-pull amplifier or for a inverter the Power is calculated by avg current, which will be close to zero (except leakage current)."
What about the switching - not ideal square waveforms, but (say) trapezoidal? Then power is dissipated during the transitions. You'll integrate a product of two waveforms linear in time, so the result will be t3/3. Along with some 2 here and there, I believe you get a factor of 6 i.e; Pdiss = VmaxImax/6.
Only for Class A are V & I in phase (modulo 180 degrees).
M.G.Rajan
www.eecalc.com
SRF Tech
Arizona
Reply #7 - Feb 9th, 2007, 9:57am
Bharat,
I think the discussion got confused regarding the situation in which power is being measured, so your question is not surprising.
As for your question, when a circuit is present, and power is being dissipated between VDD and VSS, as long as total current paths are accounted for, you can monitor the current flow into either VSS (When considering current sinking into VSS, ensure you are accounting for load currents as well as the buffer) or out of the VDD node, either way, you are measuring the flow of current at a given voltage, from this you calculate the power you are looking for  (DC, average, RMS, etc).
-SRF Tech
