jbdavid
I was hoping to use these, to get current density warnings, but spectre manuals tell me these are Amps/um^2.. I'm assuming 1 dimension is transistor W, but the other cannot be Length.. , has to be depth.. of WHAT?
What I want to specify is similar to TSMC manual, Jeff = Id/w
BSIM spec does NOT mention these parameters at all.. and Spectre manual doesn't explain how to get Jds from Ids!
Guess I have to write assertions for this instead.. If someone knows what thickness would be used, please post it here..
