There are many discussions on this forum about stability analysis. Spectre has an analysis (which improves upon Middlebrook's method) for analysing stability withing requiring you to break the loop(s). Loading is correctly handled as a result using stb analysis. You should find a number of postings about this by using the Forum's search facility.
