Aug 16th, 2024, 10:15pm
huge spike in PLL CP noise current simulation (Read 3090 times)
rfic
San Diego, CA
Jan 30th, 2007, 3:32pm
hi, i'm simulating PLL phase noise contribution from CP. when i use PLL+Pnoise to simulate the CP/PFD noise current output, i see a huge spike at comparison frequency.
how this spike generated? is there any relationship to reference spur (or i should ask: can i use this spike to simulate reference spur)
thanks
Visjnoe
Re: huge spike in PLL CP noise current simulation
Reply #1 - Jan 30th, 2007, 11:55pm
Dear rfic,
what you see in your simulation is most likely the reference spur.
It can be caused by:
1) mismatch between CP UP/DOWN currents
2) CP/LF leakage current
3) timing mismatch between UP/DOWN signals
I would guess that the spur you see will be largely caused by (1)...
Kind  Regards
Peter
rfic
San Diego, CA
Reply #2 - Jan 31st, 2007, 10:06am
hi, peter,
thanks for reply. I fully agree with the cause of reference spur.
In fact, my concern is:
1. as u say, the reference spur is caused by mismatach/leakage CURRENT, in stead of CURRENT NOISE ; but the spike i see is in Pnoise result (i check the current noise); do u think these 2 are in fact same thing?
2. i normally use CP current noise (simulate with PSS+Pnoise) to calculate pn due to CP, i have compared simulation to measurement, they're reasonablely close; but i never check current noise at comparison frequency until recently I happen to see this spike.
mathmatically, this spike is due to convolution of huge flicker noise value at 0-frequency with square wave; but physically, what it mean?
thanks
David Lee
Reply #3 - Feb 1st, 2007, 11:59pm
This is usually due to 1/f noise up converted to the comparison frequency.
Is the top noise contributor a 1/f noise source?
- David
