Aug 16th, 2024, 6:28pm
Divider retiming strategy (Read 2926 times)
Visjnoe
Jan 31st, 2007, 7:41am
Dear all,
consider an asynchronous div-by-N divider which is retimed by a FF. Assume the input of the divider is clocked at the positive edge of the incoming (clock) signal.
At which edge should the retiming FF be clocked? I would guess that the negative egde is the better choice
(robustness).
Further on: are there better retiming strategies or is the single FF most common?
Kind Regards
Peter
mg777
Re: Divider retiming strategy
Reply #1 - Feb 1st, 2007, 9:08pm
Is there clock recovery involved?
A robust sampling strategy would be to do an early-late comparison with a DLL. This may be economical only for specialized blocks, not for cells. It's interesting how analog and digital folks treat timing closure very differently.
M.G.Rajan
www.eecalc.com
Visjnoe
Reply #2 - Feb 1st, 2007, 11:54pm
Dear mg777,
there is no clock recovery involved: it's just retiming of a divided CLK to minimize the jitter through accumulation by an asynchronous divider.
If the divider is triggered by pos edge of the input, I would think it is not save to trigger the retiming FF at the output by the same pos edge of the input, for reasons of FF set-up/hold time basically.
Kind Regards
Peter
