Pavel
Hello
I have 2 question concerning using of Schematic Tracer:
1. Can I select signals/modules directly in schematic window. This feature doesn't clearly explained in SimVision manual. For the moment I succeded to make selection only in Design Browser (panel on the left, pls, see the picture). Modules I select with left button. For signals only right button works... Why? When I try to select an object (signal or module) in schematic window (panel on the right), object is highlighted for a fraction of second, and then deselected. According to SimVision manual, in order to trace between 2 object, one must select 1st object, and then keeping Ctrl, select second. As I understand it concerns only Tracer Schematic window, not Design Browser. So for the moment this feature is inaccessible for me. Is it tool bug or should I change some tool settings.
2. To do full tracing of a signal is it necessary to specify in Hierarchy Editor -> AMS -> Save/Plot saving all the signals? I specified saving/plotting of the limiting number of signals and when I try to find driver(s) for particular signal, tracing stopped at signal itself and doesn't show its driver(s).
Regards.
Pavel.
