May 15th, 2024, 5:34pm
using of SimVision Schematic Tracer (Read 3992 times)
Pavel
Lausanne/Switzerland
Jan 31st, 2007, 2:50am
Hello
I have 2 question concerning using of Schematic Tracer:
1. Can I select signals/modules directly in schematic window. This feature doesn't clearly explained in SimVision manual.
   For the moment I succeded to make selection only in Design Browser (panel on the left, pls, see the picture).
   Modules I select with left button. For signals only right button works... Why?
   When I try to select an object (signal or module) in schematic window (panel on the right), object is highlighted for
   a fraction of second, and then deselected.
   According to SimVision manual, in order to trace between 2 object, one must select 1st object, and then keeping Ctrl, select
   second. As I understand it concerns only Tracer Schematic window, not Design Browser. So for the moment this feature is inaccessible for me.
   Is it tool bug or should I change some tool settings.
2. To do full tracing of a signal is it necessary to specify in Hierarchy Editor -> AMS -> Save/Plot saving all the signals?
   I specified saving/plotting of the limiting number of signals and when I try to find driver(s) for particular signal, tracing stopped at signal itself and doesn't show its driver(s).
Regards.
Pavel.
