Jul 23rd, 2024, 3:23pm
operating point info in MDL? (Read 3371 times)
topquark
Thames Valley, UK
Feb 01st, 2007, 7:37am
Hello folks,
While I'm able to plot all sorts of expressions(using calculator functions) defined in my MDL script, I find it puzzling to get operating point info like gm, Vth etc..
While these are present in the psf dump of the Analog Design Environment, I can't see a similar thing in the .raw o/p of the MDL
Plz share any ideas people!
Gau
topquark
Thames Valley, UK
Re: operating point info in MDL?
Reply #1 - Feb 3rd, 2007, 4:24am
well, i know it's weekend..but, just in-case any of you scripting experts logged in  :P
care to help me out!
This thing's been bugging me..
The idea is to be able to plot, say threshold voltage of a device Vth as a function of sweeping supply VDD. I'm aware I can do this as a paramteric analysis in ADE but, I'm hampered by limited measurement capabilites therein.
So, I write this MDL script to do some measurements involving VDD as a variable which keeps changing during each sweep.
Have you folks used a syntax to get a device's operating point info like Vth, gm in MDL?
Appreciate your comments
Ciao
Gau
Scott Flinchbaugh
Reply #2 - Feb 5th, 2007, 7:04pm
Gau,
There are a couple of ways to accomplish this.
The most desired way is to embed this information into your "alias measurement" with statements such as:
export real myvth = <devicename>:vth
Or in a more generic fashion:
export real <MDLparamname> = <devicename>:<device_parametername>
To obtain the operating point data for a device, you simply need to access the device's op output parameter.
This will place the MDL variable "myvth" into the .measure file generated by MDL and will also place it
into the psf files generated by MDL.
Another way to do this is to use the Spectre save statement here.  The syntax is a bit different:
save <devicename>:<device_parameter>
Hope this helps,
-scott
View Profile flinchba   IP Logged
topquark
Thames Valley, UK
Reply #3 - Feb 6th, 2007, 12:35am
Hey Scott
Thanks pal.. that was very helpful indeed!!
Just another particular though-
For e.g you want vth of a pmos device MP1, you will have to write the MDL statement as
export real myvth = MP1.m1 : vth
Without .m1 , the script still runs without errors  but  doesn't output vth of the required device.
The same applies to even the save statement in spectre.
Cheers,
Gau
Reply #4 - Feb 6th, 2007, 6:53am
topquark wrote on Feb 6th, 2007, 12:35am:
That's almost certainly because MP1 is a subckt in your library, and the actual device is "m1"
