Bill Toole
Thanks Sheldon
I had not set a value for tstab but, as the guide specifies, it defaults to "one cycle of the signal period". Setting tstab to 0, as you pointed out, forces it to run a pure HB sim. I had read the relevent section before but missed the bit about tstab. I am still not clear what it does with the transient when tstab is not set to 0. I assume it uses it as an intial guess for the HB solution, similar to what "Transient Assisted Harmonic Balance" (TAHB) does in RFDE and GoldenGate. However, in RDFE and GoldenGate TAHB, it runs the trasient only for the first value in a swept sim, not every swept value. I also don't like the fact that for a two tone HB PSS you still have the set the beat frequency, and, if the tone are close together, you have to set a large number of harmonics, which significantly slows things down. It appears that QPSS is the better sim to run, which, is what they suggest in the guide.
Bill
