Jul 23rd, 2024, 11:18am
Cadence simulation problem (Read 2280 times)
wccheng
Feb 05th, 2007, 12:26am
Dear all,
I have a question about the Cadence simulation setting. I hope you could help me. In our simulation, I need to edit the “input.scs” file. After I finished the edition and press the "RUN”icon in the Analog Design Environment Windows. The simulated result is same as the netlist I changed before. However, I run the
"runSimulation” script file in the command prompt. It could give out the edited result. Why will it happen? How could I set that it could allow me to press RUN icon in ADE instead?
wccheng
bernd
Munich/Germany
Re: Cadence simulation problem
Reply #1 - Feb 5th, 2007, 2:01am
I've you use the run icon or the run menu item ADE will take your previously
netlisted design out of the machines memory.
Try
-  "Simulation -> Netlist -> Recreate"
- Edit the netlist
- Run (run only!) the simulator again.
The netlist recreate action will force ADE to use the netlist form disk.
Bernd
Just another lonesome cad guy
Reply #2 - Feb 6th, 2007, 4:23pm
Why do you need to edit the netlist? Knowing that might allow me to give a better way of achieving what you're really tring to achieve.
