wccheng
Dear all,
I have a question about the Cadence simulation setting. I hope you could help me. In our simulation, I need to edit the “input.scs” file. After I finished the edition and press the "RUN”icon in the Analog Design Environment Windows. The simulated result is same as the netlist I changed before. However, I run the "runSimulation” script file in the command prompt. It could give out the edited result. Why will it happen? How could I set that it could allow me to press RUN icon in ADE instead?
wccheng
