Jul 16th, 2024, 10:45am
Overlap Capacitance (Read 1218 times)
aaron_do
Overlap Capacitance
Feb 06th, 2007, 10:53pm
i'm trying to calculate the gate drain capacitance in the subthreshold region for a nmos. I'm using the BSIM3.2 model, and i figured for a good approximation I only need the Gate Drain overlap capacitance. This was mentioned in the book by T.H. Lee. Is this correct?
Ok part 2. In the manual it says Cij=dQi/dVj. i.e. Cgd=dQd/dVg and Cgd is reciprocal. However, the equation given is Qd versus Vgd. Can I say Cgd=dQd/dVgd?
OK assuming I do the differentiation, I get an equation in terms of Vgd. So should I then sub in the DC value?
thanks for the help,
Aaron
Re: Overlap Capacitance
Reply #1 - Feb 7th, 2007, 7:04am
aaron_do wrote on Feb 6th, 2007, 10:53pm:
In subthreshold, Qd for the channel should be zero, so yes, that's a good approximation.
You mixed up your formula; Cgd = dQg/dVd.  Cgd for the channel is not reciprocal.  Is Cgdov only a function of Vgd?  Is the equation for Qd for the channel charge or only the overlap charge?
aaron_do
Reply #2 - Feb 7th, 2007, 5:54pm
thanks for your reply.
I rechecked the BSIM3.2 manual, and it definately says Cgd is reciprocal. In the manual, Cgs is a function of Wactive (approximately the width), CGD0, CGD1, CKAPPA and another constant (equal to .02). I think CGD0 and CGD1 are dependant on the overlap length and Cox.
By the way, why wouldn't a capacitance be reciprocal? Is it not based on a physical model? I'm totally new to modeling and completely confused, so thanks for any help,
Aaron
337see733
Singapore
Reply #3 - Feb 7th, 2007, 7:57pm
TRUE only at Vds=0 or Vd=Vs.
Also,
Cgd,ov = dQg,ov/dVd, should not be dVgd.
But, I'm not sure whether there is anyway to calculate Qg,ov(overlap Qg) in BSIM ?
View Profile gilbertsee   IP Logged
aaron_do
Reply #4 - Feb 7th, 2007, 9:12pm
I see. thanks. I think i need to just pick up a good book...My knowledge on this topic is too basic.
thanks Anyway.
Aaron
Reply #5 - Feb 8th, 2007, 11:18am
aaron_do wrote on Feb 7th, 2007, 5:54pm:
For a MOS, there are 4 terminals, and you get non-reciprocality from idealizations like charge-sheet approximation and the partitioning of the channel charge.
