danda821
When I use AMS Netlister netlist some circuit block, it generates several error:
Error: Value "1" of property "m" (CDF name "m") on instance "T0" is a string. Ensure that value of "m" factor property is of type integer or real. ...... where T0.. are transistor in a kit.
So I use CIW->Tool->CDF->Edit... to change CDF, but since the transistor is from a design kit, I can only open it in "read-only" mode. Is there anyway to overcome this problem? Thanks.
danda821
