Jul 16th, 2024, 3:52am
AM-to-PM conversion (Read 567 times)
rfmems
AM-to-PM conversion
Feb 16th, 2007, 3:25pm
Amplitude noise to phase noise conversion carried out by the varactor in VCO is one of the phase noise sources. What I can not understand is:
the am noise modulating the varactor has to be low frequency to be converted to PM around the carrier, however the low frequncy am noise is attenuated by the LC tank and thus should be small, while the am noise at frequency around the carrier can only be converted to pn noise far away from the carrier. Then there should be very tiny amount of am noise converted to PM around the carrier, which is opposite to my simulation and experience.
What I have misunderstood? Please help me out.
RFICDUDE
Re: AM-to-PM conversion
Reply #1 - Feb 16th, 2007, 8:45pm
The varactor has only one terminal connected to the tank, the other terminal is connected to the control voltage input. Any noise present on the control input will modulate the capacitance of the varactor and thus modulate the frequency (or phase) of the VCO which shows up as PM noise around the carrier.
