Oct 5th, 2024, 11:25pm
Input and output capacitance of min size inverter (Read 3074 times)
MTXamp
Singapore
Feb 17th, 2007, 9:50pm
Hi
I am trying to find the input and output capacitance of a min size inverter for a 0.35um process. To find the input capacitance, I used the circuit as shown on the left of the attached picture. Voltage source V5 was ramped up from 0 to Vdd in a tranisent simulation. Since I=C(dv/dt), the graph of I/(dv/dt) was plotted against Vin to find C. The same method was used for the output cap except that 1G ohm resistors have been inserted at the rails to take care of the low resistance path provided by both rds resistors.
The ratio of output to input cap was found to be 2.8fF/2.0fF. May I know if this is actually possible? I thought that the gate capacitance is supposed to be the largest cap in the whole device.  :-? Is there anything wrong with the method which I have employed?
Quek
aaron_do
Re: Input and output capacitance of min size inver
Reply #1 - Feb 20th, 2007, 10:30pm
The circuit can't turn on with 1G resistors there...
fonseca.ha
UK
Reply #2 - Mar 7th, 2007, 3:57am
The drain/source of the mos are the other terminals of the gate capacitance. In the circuit of the right, when the output voltage is low, looking into the drain of the NMOS you should have half of the capacitance seen when looking from the gate.
Than you must also add the capacitances from the PN junctions in the drain of both the PMOS and the NMOS transistors. The result is not very surprising for me,
Humberto
Croaker
Reply #3 - Mar 12th, 2007, 7:10am
So what is the correct method in general to measure capacitance using a simulator?
Do you ramp voltage and plot i/(dv/dt)=C?
