Oct 6th, 2024, 1:19am
using waveform calculator with xf analysis (Read 609 times)
vivkr
Mar 09th, 2007, 1:03am
I am running an XF analysis to find the transfer functions from various input sources to a
single output, and I am able to do everything well.
However, I don't know how I can predefine certain outputs for plotting. For other analyses
(AC, DC, Tran), I can create predefined outputs, e.g. VDC("/vx"). How does it work with
XF analysis?
Vivek
ACWWong
Oxford, UK
Re: using waveform calculator with xf analysis
Reply #1 - Mar 9th, 2007, 2:32am
you can use
getData("/vx" ?result "xf")
this syntax can also be used for results from all analysis. VT, VDC etc are older ways to access the results.
A good way I use is to use the GUI (ADE) and the "Add to Outputs" option on the Results->MainForm to get the results expressions.
vivkr
Reply #2 - Mar 9th, 2007, 3:17am
Thanks so much. It works well. I will be sure to use this method more often.
Vivek
