fonseca.ha
UK
The drain/source of the mos are the other terminals of the gate capacitance. In the circuit of the right, when the output voltage is low, looking into the drain of the NMOS you should have half of the capacitance seen when looking from the gate.
Than you must also add the capacitances from the PN junctions in the drain of both the PMOS and the NMOS transistors. The result is not very surprising for me,
Regards, Humberto
