Jul 16th, 2024, 10:04am
LNA and Mixer Gain (Read 3156 times)
sandman
LNA and Mixer Gain
Feb 20th, 2007, 11:10am
Would anyone be aware of the simplest method to estimate the gain of a front end comprising of an LNA and a Mixer in Cadence-SpectreRF ? As of now I'm using PSS and PXF (to allow for the frequency translation from the mixer) to estimate combined gain. The results are quite different from what I'd expected. So, any inputs would be much appreciated.
Cheers.
aaron_do
Re: LNA and Mixer Gain
Reply #1 - Feb 20th, 2007, 10:05pm
Are you asking for a simple method to estimate the gain in Simulation or make an estimate based on knowledge of the LNA and mixer.
If you're talking about by simulation then you're using the right method.
Otherwise its just the gain of the LNA in dB plus the gain of the mixer in dB. You have to take the loading into account too. If your mixer uses large device size it may be lowering the voltage gain of your LNA. Maybe you can use the XF (transfer function) simulation of the LNA+Mixer taking the output at the LNA output node to troubleshoot.
Aaron
sandman
Reply #2 - Feb 21st, 2007, 1:17am
This is the simulation I'm concerned about. Thanks for your inputs.
I tried the XF for the LNA and find that it gives me a different result for voltage gain than the PSS simulation. I don't understand how these simulations work, so is there a reason why they are different ?
I wanted to confirm if the PSS+PXF for LNA+Mixer gives the Voltage gain and not the power gain.
Cheers.
Reply #3 - Feb 21st, 2007, 9:15am
It is hard to help you because you have given no specifics. For example, how did you set up the PXF and how do the results differ.
PXF and PSS naturally produce different results. PXF produces the gain and PSS calculates a voltage level. So you have to divide the PSS output voltage and input voltage to compare them. Furthermore, if your stimulus is being provided by a port, PXF is computing the gain assuming a perfect match at the input. In other words, it is computing the gain from the voltage source that is internal to the port, and dividing it by two.
If you are using a port as stimulus, you might want to use PAC rather than PXF. This way Spectre will compute both the input voltage and the output voltage, just like in PSS, and you can find the gain by dividing them.
