Axholt
I noticed how Assura RCX extracted caps that allready was modelled in my transistor-model and started to wonder how to get rid of these. I also noticed how there was an layer in my layout (in the pcell) who's function was to "block the extractor from extracting caps". After reading the Assura manual I figured out that I need to set an option for the capgen (-blocking 'blocklayer',M1,M2,M3.....) to enable this feature.
{Capgen is beeing executed ones I click on "run" in the Assura RCX GUI.}
My problem is now, where do I set this blocking option? There is no field in the Assura RCX GUI where I can pass on options. My guesses are that the GUI generates a script which is then beeing executed, where do I find the "frame" for this script?
Thank you for your help,
Andreas, Sweden
