Jan 13th, 2026, 4:02am
'RAMP attribute in Cadence (Read 7148 times)
wprodanov
Genoa, Italy
Feb 22nd, 2007, 8:29am
Hello mates,
I'm using ncsim simulator (Cadence IUS 5.7). When using 'RAMP attribute to define a voltage quantity from a voltage signal, sometimes the resulting quantity doesn't varies linearly as expected. Instead, it is "updated" abruptly only at the instant when the variation should finished. Anyone have seen the same behavior? Any idea how to work around?
thanks
william
abhi_kolpekwar
Re: 'RAMP attribute in Cadence
Reply #1 - Feb 22nd, 2007, 1:32pm
Are you setting a  "break" on the signal that is used in the RAMP attribute?
wprodanov
Genoa, Italy
Reply #2 - Feb 23rd, 2007, 2:24am
According to the language standards the use of break is not necessary when using 'RAMP, isn't it? Anyway, thanks for replying and I'll check the difference using or not using it.
alinalin19832007
roman
Reply #3 - May 29th, 2008, 1:14pm
Maybe the step time for the analog solver it is not constant
