I must admit I thought what Ken did - I couldn't see why you would do this - the response will be independent of the operating point, since it is linear time invariant.
Anyway, there's no need to do the actimes in the netlist. It can be done from the GUI.
If you have a recent enough IC version, setup the ac analysis as usual. Then on the transient options form, go down to the field actimes - and enter space-separated times. The acnames field will open up, and you would specify the names of the ac analyses you want to run at these times. So enter "ac" in that field (the ADE interface will call the instance name of the analysis the same as the name of the analysis itself - so enter ac, xf, noise etc).
If you're using an older version where acnames/actimes doesn't appear on the transient options, scroll down to the bottom of the transient options form, and in the additional options field, type:
Code:acnames=[ac] actimes=[10u 20u 30u]
If you haven't got the additional parameters field (which appeared in IC5141 USR2), you'd have to go to a netlist-based approach (perhaps with an include file for the analyses). You'll need an MMSIM version of spectre to handle this.
Of course, with your circuit, you'll just see the same frequency response multiple times...
