Aug 16th, 2024, 2:30pm
PSS+PNoise question (Read 3636 times)
xuel
PSS+PNoise question
Mar 01st, 2007, 1:15am
I use pss+pnoise to simulate the noise of a switching circuit, in pnoise setup, choose jitter as noise type.
And I get a result of 10mV integrated noise. The question is is this value rms-noise or peak-noise?
Re: PSS+PNoise question
Reply #1 - Mar 1st, 2007, 6:47pm
It's got to be RMS. Peak is not defined for Gaussian noise.
xuel
Reply #2 - Mar 4th, 2007, 7:49pm
from the equation (19) on page 8 of "Modeling Jitter in PLL-based Frequency Synthesizers", the edge-to-edge jitter is calulated as:
Jee=sqrt(var(nv(tc)) / (dv(tc)/dt)
if var(nv(tc)) is rms noise, Jee should be rms jitter? I am puzzled.
Reply #3 - Mar 5th, 2007, 3:51pm
Yes, Jee is RMS jitter.
You might want to update you version of that paper. Eqn (19) is no longer on page 8, and the equation you give is not Eqn (19).
