May 15th, 2024, 7:21am
SpectreVerilog Problem (Read 3272 times)
danda821
Mar 01st, 2007, 11:25am
I am using SpectreVerilog. If I use functional view for digital blocks, I got x state for all digital signal. If I use spectre model for all blocks (digital and analog), or use spectre model for some digital blocks, the simulation results are right. It seems like the timing is right only after binding some digital blocks to spectre model. I tried timescale of 10p/1p, 100p/1p, no different.
Can someone help me on this? thanks.
bernd
Munich/Germany
Re: SpectreVerilog Problem
Reply #1 - Mar 2nd, 2007, 3:13am
This may result because of
- non proper initialized digital blocks, you may
 forgot to reset some FF?!
- or wrong timing and/or delay options settings
 for an explanation have a look at the attached pdf.
Bernd
Just another lonesome cad guy
danda821
Reply #2 - Mar 2nd, 2007, 7:56am
Thanks. I used the global timescale as you mentioned in the pdf file. There are many dff without RS in my circuit, which may cause the problem. Is there anyway to initilize them in spectreverilog? Thank you.
bernd wrote on Mar 2nd, 2007, 3:13am:
Bernd
