I'm not really familiar with Calibre, but what should be happening is that when the layout is streamed out (the GDS file is created), one of the layout views will have its name changed - because stream format only has cell (structure) names. I think you should be able to check the PIPO.log file to see what remapping was done (we have a power outage in my office at the moment so I can't connect to take a look).
Then with Calibre you should be able to create an "hcell" file which gives the mapping of layout name to schematic name. You'd need to include two bindings (I think) for the mappings of whatever the views ended up named as in the stream (GDS) file to whatever the common schematic cell name.
I don't know this for certain, but I think it would be something along these lines.
