Aug 16th, 2024, 12:33pm
input clock jitter (Read 2905 times)
sivacharan
input clock jitter
Mar 06th, 2007, 2:01am
My Q is regarding how can we specify input clock jitter in cadence?
Assume that i am using vpulse from analogLib as a clock.
I am unable to figure out where i can give the input clock jitter??
Thanks.
Re: input clock jitter
Reply #1 - Mar 6th, 2007, 9:48am
The built-in sources do not implement jitter. You will need to use Verilog-A instead. Look on verilog-ams.com to find fixed-frequency oscillators (with and without jitter).
