Oct 6th, 2024, 5:23am
A question about ring VCO in gm-c filter automatic (Read 2245 times)
smellyegg
Beijing, P.R. China
Mar 06th, 2007, 10:07pm
The following VCO schematic( in the attachment) is used for gm-c filter automatic tuning, however, it doesnot oscillate. According to the theory, the last transconductor is used as a negative resistor, which maintains the oscillation, while the first two transconductors as well as the two capacitors are working as an inductor. When I adjust the value of C1 and C2, the output waveform doesnot change at all, however it should change, as the frequency of the output waveform is determined by gm/c.
Are there some special attentions that should be paid to while designing the three transconductors? Thanks.
Victor Chu
View Profile smellyegg   IP Logged
fonseca.ha
UK
Re: A question about ring VCO in gm-c filter autom
Reply #1 - Mar 8th, 2007, 8:32am
maybe it needs an initial condition that puts it out of equilibrium, and trigger the oscillation,
I think that both capacitors should have the same value, try bracking it in parts to check where the problem comes from.
If you remove the OTA  in the right hand side and put an initial condition on the left circuit you should observe a dumped oscillation, does that happen?
smellyegg
Beijing, P.R. China
Reply #2 - Mar 8th, 2007, 5:36pm
Thank you very much. Yes, it needs an initial condition which triggers the oscillation. When I set the initial voltage of Vo2 to be 2 volts, it becomes much easier to oscillate. And there is another problem with this circuit, which lies on the common mode feedback circuit of the OTA. The W/L values of the input transistors of the CMFB are set to be too large, and when it is set to be smaller, the oscillation also occurs. Thanks again for your help. May you a nice day.^_^
Victor Chu
